Potential causes for DataMiner Cube to switch to polling?
Solved3.08K views10th July 2023Cube firewall polling
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K 19th August 2020 0 Comments
Has anybody experience with situations that can cause a Cube to switch to polling for other reasons than ports being blocked (i.e. allegedly all proper ports are open, and Cube keeps falling back to polling)?
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 19th August 2020 0 Comments
When Cube connects to the DMA, Cube will open a random port to which the DMA has to connect to send eventing notification messages. If only Cube is able to connect to the DMA, and the DMA not to Cube, then Cube switches to polling. This happens when ports towards the client are blocked, or when the client is behind NAT, which makes that the DMA isn't able to connect to Cube on the client machine.
