post api call on button click
Solved2.71K views4th October 2024post api protocol togglebutton
Chirangee lal Verma [DevOps Member]555 1st October 2024 0 Comments
  1. getting data  through  Api call, now for edited and completed job status rows  i need to show start in update job status column and for running job status stop
  2. on toggle i need to send a post api (start or stop ).so how will be the flow for that .
Chirangee lal Verma [DevOps Member] Selected answer as best 4th October 2024
Chirangee lal Verma [DevOps Member]555 Posted 3rd October 2024 1 Comment
hi jose silva,
thanks for reply see this code once i m getting respective data in log but not in table
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Globalization;
using System.Text;
using Newtonsoft.Json;
using Skyline.DataMiner.Net.NetworkDiscovery;
using Skyline.DataMiner.Scripting;
public static class Parameter
public static class Jobs
public const int TablePid = 210; // Table ID for the Jobs table
/// <summary>
/// DataMiner QAction Class.
/// </summary>
public static class QAction
/// <summary>
/// The QAction entry point.
/// </summary>
/// <param name="protocol">Link with SLProtocol process.</param>
public static void Run(SLProtocol protocol)
try
// Get the JSON data as a string from a parameter (e.g., parameter ID 200)
string source = Convert.ToString(protocol.GetParameter(19));
// Deserialize the JSON content into C# objects
Rootobject rootObjects = JsonConvert.DeserializeObject<Rootobject>(source);
List<object[]> jobs = new List<object[]>();
// Iterate over each job in the JSON and map it to the table structure
foreach (Job job in rootObjects.Jobs)
string buttonAction = GetButtonForJobStatus(job.Job_Status);
protocol.Log(buttonAction + "data for button ");
jobs.Add(new JobsQActionRow
Jobname_201 = job.Job_Name,
Jobtype_202 = job.Job_Type,
Jobstatus_203 = job.Job_Status,
Updatedtime_204 = job.Updated_Time,
Nodename_205 = job.Node_Name,
Button_206 = buttonAction,
}.ToObjectArray());
// Insert the data into the DataMiner table (with table PID 301)
protocol.FillArray(Parameter.Jobs.TablePid, jobs, NotifyProtocol.SaveOption.Full);
catch (Exception ex)
protocol.Log("QA" + protocol.QActionID + "|Deserializing JSON text failed: " + ex.Message, LogType.Error, LogLevel.NoLogging);
private static string GetButtonForJobStatus(string jobStatus)
switch (jobStatus.ToLower())
case "running":
return "Stop";
case "edited":
case "completed":
return "Start";
default:
return "Unknown"; // Handle unexpected statuses
public class Rootobject
public Job[] Jobs { get; set; }
public class Job
public string Job_Name { get; set; }
public string Job_Type { get; set; }
public string Job_Status { get; set; }
public string Updated_Time { get; set; }
public string Node_Name { get; set; }
/// <summary>
/// Class to represent a row in the DataMiner table.
/// </summary>
public class JobsQActionRow
public string Jobname_201 { get; set; }// Column 201: Job Name
public string Jobtype_202 { get; set; }// Column 202: Job Type
public string Jobstatus_203 { get; set; }// Column 203: Job Status
public string Updatedtime_204 { get; set; }// Column 204: Updated Time
public string Nodename_205 { get; set; }// Column 205: Node Name
public string Button_206 { get; set; }
// Convert the properties to an object array for insertion into the DataMiner table
public object[] ToObjectArray()
return new object[] {
Jobname_201, // Maps to Column 201
Jobtype_202, // Maps to Column 202
Jobstatus_203, // Maps to Column 203
Updatedtime_204, // Maps to Column 204
Nodename_205, // Maps to Column 205
Button_206,
José Silva [SLC] [DevOps Enabler] Posted new comment 3rd October 2024
José Silva [SLC] [DevOps Enabler] commented 3rd October 2024
Hi Chirangee,
See my response below
