Ports for element replication
Solved502 views20th February 2026GRPC connection replicated element
Ruben Vandepitte [SLC] [DevOps Advocate]2.39K 22nd September 2025 0 Comments
What ports need to be open between source and target system for element replication:
  • In case both systems are not configured for gRPC
  • In case both systems are configured for gRPC
  • In case only the source system is configured for gRPC
  • In case only the target system is configured for gRPC
Thanks!
Bert Vandenberghe [SLC] [DevOps Enabler]9.68K Posted 25th September 2025 0 Comments
Hi Ruben,
If you add a replicated element on a DMA, it doesn't matter if that DMA is configured to use gRPC or not. This has nothing to do with it.
This replicated element needs to get its data from somewhere. A regular element gets the data from the actual device or service. With a replicated element, it will get the data from another DMA by connecting to that DMA just like Cube would do. So, it only depends on how this DMA, hosting the original element, is configured:
  • with gRPC: only TCP port 443 towards that DMA hosting the original element needs to be open.
  • without gRPC: TCP port 443 and 8004 (or whatever port which was chosen for .NET Remoting, default is 8004) need to be open towards that DMA hosting the original element
This is also nicely explained here: Replicated elements | DataMiner Docs
PS: I deliberately avoided the wording source and target system because I got confused what is what...
Bert
