Permissions Dashboard changed, now scheduld task is not running
412 views5th January 2026Automation script Cube dashboard access Scheduler Task
Pascal Puzio [DevOps Advocate]20 5th January 2026 0 Comments
We have dashboard, where had to change the persmissions from everyone to selected groups.
From this dashboard we have in cube daily scheduld task running, to create a report. Since we change this persmissions from this dashboard, the scheduler cannot run this task anymore, because the dashboard not availble. It is in displayed in red.
It looks that scheduler / automation script / Cube don't have the permission to access this dashboard anymore.
Can someone tell me which dashboard persmissions are required for the scheduler / automation script / cube to access it?
Thanks.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 5th January 2026
Wout Mahieu [SLC] [DevOps Catalyst]11.50K Posted 5th January 2026 6 Comments
Hi Pascal,
What DataMiner version are you using? We have recently changed the behavior of this so that non-public dashboards can be used in the scheduler. This is available from DataMiner 10.5.10 onwards.
Wout Mahieu [SLC] [DevOps Catalyst] Posted new comment 6th January 2026
Pascal Puzio commented 5th January 2026
Hi Wout,
We running currently version 10.5.7.0. What are the changes then? If you work with permissions?
Wout Mahieu [SLC] [DevOps Catalyst] commented 5th January 2026
Before the change, it wasn't possible to use dashboards that weren't public (eg: a specific user/group has view permissions) in the scheduler. With this change, all dashboards can be used.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 5th January 2026
Hey Wout, with 'all dashboards' you probably mean the dashboards you have access to with the user your are logged in with in Cube?
Wout Mahieu [SLC] [DevOps Catalyst] commented 6th January 2026
Hi Pieter, that is correct. Only dashboards that can be accessed by the logged in user are configurable in the Scheduler module.
Pascal Puzio commented 6th January 2026
Hi Wout,
Not sure of we see the behaviour like you mention, some dashboard are visible in the schedular. some are not, the have all the same group rights.
Sitting now a little bit in the dark. I put the settings back, the dashboard is still not visible.
Show 1 more comments
