Passing script parameters with # reserved character
Solved1.58K views24th March 2021
Jon Morley10 23rd March 2021 0 Comments
I am passing script parameters but am finding that if a parameter contains the # reserved character the script does not run and I get the error box showing that parameter as 'blank'.
My Shape Data calling the script is:-
Script:X20 MTX||Output_Port_PRI=[property:x20IRS_Output_Port_PRI];Output_Port_SEC=[property:x20IRS_Output_Port_SEC];PlayoutServer=[var:PlayoutServer[property:x20IRS_Output_Port_PRI]];PRI_ElementName=[property:x20IRS_PRI_ElementName];SEC_ElementName=[property:x20IRS_SEC_ElementName];Source=PlayoutServer;PRI_ElementName_ENC=N/A;Output_Port_PRI_ENC=N/A;SEC_ElementName_ENC=N/A;Output_Port_SEC_ENC=N/A;ServiceName=[this service]||Switch to [var:PlayoutServer[property:x20IRS_Output_Port_PRI]] Playout Server on [property:x20IRS_PRI_ElementName] and [property:x20IRS_SEC_ElementName]|CloseWhenFinished,NoConfirmation,NoSetCheck
The PlayoutServer script parameter can contain a # character, the value passed in could be:-
#BAN_TSG_1080i50_BLACK
I've tried using [Sep:#^] without any success, or I'm putting the Sep in the wrong place.
Thank you for any help.
Jon
Jon Morley Selected answer as best 24th March 2021
Leander Druwel [SLC] [DevOps Member]2.10K Posted 23rd March 2021 2 Comments
Indeed, I notice the same behavior when trying this internally. Cube also adds a log line with the message 'Value does not fall within the expected range'.
I'm not aware of a possibility to escape this, however I do notice that it only seems to happen if your parameter value starts with the '#' character. An alternative solution could be adding a prefix to the Shape Data, which could then be stripped off again, i.e. replacing 'prefix#' to '#' in the automation script that is executed. Probably not the ideal solution and most fancy solution but it is quite similar to escaping a char.
Script:Automation script||Param=prefix#test|||NoConfirmation
Jon Morley Posted new comment 24th March 2021
Miguel Obregon [SLC] [DevOps Catalyst] commented 24th March 2021
Just adding a small note. The hash character (‘#’) is reserved in this context to indicate DataMiner that the parameter is assigned to as so-called permanent memory file (i.e. an array of values). Additional information in DataMiner Help:
https://help.dataminer.services/dataminer/#t=DataMinerUserGuidepart_2visioLinking_a_shape_to_an_Automation_script.htmXREF_73954_11_2_13_Linking_a&rhsearch=overviewshape&rhsyns=
Jon Morley commented 24th March 2021
Hi Leander and Miguel, thank you for the replies. We worked around the problem by prefixing every value that would be passed to the script with a whitespace, and compensating for that in the automation script using the script params.
