Passing Script Parameters using a correlation action to C#
Solved2.56K views20th February 2023
9
Oliver Wilkinson [DevOps Advocate]871 20th February 2023 0 Comments
Apologies, I know it will likely exist but I have been unable to find documentation when I was looking.
I am hoping to trigger a script from a correlation on an alarm, subsequently I will then need to do a lookup and trigger an alarm on a separate element. I can see there is a configurable option for 'Evaluate Script Parameter Values'
I wondered if there is a way I can pass information about the alarm that triggers the script to the C# code so that I can action on parameters that exist in it? i.e. the ID of the alarm or the values that are present within it?
Many thanks
Oliver
Tom Waterbley [SLC] [DevOps Enabler] Answered question 20th February 2023
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 20th February 2023 1 Comment
Hi Oliver,
This is certainly possible. See the bottom note at Running an Automation script from a Correlation rule
Jens Vandewalle [SLC] [DevOps Advocate] Edited answer 20th February 2023
Oliver Wilkinson commented 20th February 2023
Thank you!
