Parameter in protocol is not refreshed
Solved1.47K views30th May 2025#editdriver dataminer driver driver driver info signings protocol
Jose Araujo [DevOps Advocate]1.01K 22nd May 2025 4 Comments
I'm developing a driver that gets information from a REST API. I'm retrieving the ping status from the endpoint into the protocol.
The issue appears when this value changes (API Status) — the parameter does not refresh. To force an update, I need to restart the element on the DMA and show current status.
Get 200  status in Wireshark, Qaction detect this but don't refresh parameter
Qaction 101
using Skyline.DataMiner.Scripting;
using System;
using System.Net;
using System.Text.RegularExpressions;
public class TimeoutWebClient : WebClient
public int Timeout { get; set; }
public TimeoutWebClient(int timeout)
Timeout = timeout;
protected override WebRequest GetWebRequest(Uri address)
var request = base.GetWebRequest(address);
if (request != null)
request.Timeout = Timeout;
if (request is HttpWebRequest httpRequest)
httpRequest.ReadWriteTimeout = Timeout;
return request;
public class QAction
public void Run(Skyline.DataMiner.Scripting.SLProtocol protocol)
try
string ip = protocol.GetParameter(15) as string;
protocol.Log("IP : " + ip, LogType.Information);
if (string.IsNullOrEmpty(ip) || !ip.Contains("."))
protocol.SetParameter(10, "Fail");
protocol.Log("Invalid IP Address", LogType.Error);
return;
string url = $"http://{ip}/api/v1/system/network/ping";
var client = new TimeoutWebClient(180000);
client.Headers[HttpRequestHeader.ContentType] = "application/json";
string response = client.DownloadString(url);
protocol.Log("Raw response: " + response, LogType.Information);
var match = Regex.Match(response, "\"ping\"\\s*:\\s*\"([a-zA-Z]+)\"");
if (match.Success)
string pingValue = match.Groups[1].Value.ToLower();
protocol.Log("Ping Value: " + pingValue, LogType.Information);
if (pingValue == "ok")
protocol.SetParameter(10, "Normal");
else
else
protocol.Log("No match found in ping response", LogType.Information);
catch (WebException ex)
protocol.Log("Ping WebException: " + ex.Message, LogType.Error);
catch (Exception ex)
protocol.Log("Ping Exception: " + ex.Message, LogType.Error);
Protocol
<Paramid="10"trending="false"save="true">
<Name>ServerStatus</Name>
<Description>API Status</Description>
<Type>read</Type>
<Information>
<Includes>
<Include>time</Include>
<Include>range</Include>
<Include>steps</Include>
<Include>units</Include>
</Includes>
</Information>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Alarm>
<Monitored>true</Monitored>
<Normal>Normal</Normal>
<CH>Fail</CH>
</Alarm>
<Display>
<RTDisplay>true</RTDisplay>
<Positions>
<Position>
<Page>General</Page>
<Row>0</Row>
<Column>0</Column>
</Position>
</Positions>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
</QAction>
<QActionid="101"name="PingCheck"encoding="csharp"triggers="10">
</QAction>
</QActions>
<Groups>
<Groupid="10">
<Name>Update Parameters basic</Name>
<Description>Updte info of Titan Live</Description>
<Type>poll</Type>
<Content>
<Param>11</Param>
<Param>12</Param>
<Param>14</Param>
<Param>15</Param>
</Content>
</Group>
<Groupid="20">
<Name>Update Parameters advance</Name>
<Type>poll</Type>
<Content>
<Param>1101</Param>
<Param>1102</Param>
<Param>1103</Param>
<Param>1104</Param>
<Param>13</Param>
</Content>
</Group>
<Groupid="30">
<Name>Health Startup Group</Name>
<Type>poll action</Type>
<Description>Health API Module</Description>
<Content>
<Action>2</Action>
</Content>
</Group>
<Groupid="40">
<Name>Healthcheck module</Name>
<Content>
<Action>2</Action>
</Content>
</Group>
</Groups>
<Triggers>
<Triggerid="1">
<Name>Health trigger</Name>
<Time>after startup</Time>
<On>protocol</On>
<Type>action</Type>
<Content>
<Id>1</Id>
</Content>
</Trigger>
</Triggers>
<Actions>
<Actionid="1">
<Name>After Startup Health Trigger</Name>
<Onid="30">group</On>
<Type>execute</Type>
</Action>
<Actionid="2">
<Name>Call Health Trigger</Name>
<Onid="10">parameter</On>
<Type>run actions</Type>
</Action>
<Actionid="3">
<Name>Login Button Action</Name>
<Onid="300">parameter</On>
</Action>
<Actionid="4">
<Name>Healthcheck Module</Name>
<Type>increment</Type>
</Action>
</Actions>
<Timers>
<Timerid="1">
<Name>health check Module</Name>
<Timeinitial="true">160000</Time>
<Interval>180</Interval>
<Content>
<Group>10</Group>
</Content>
</Timer>
</Timers>
Jose Araujo [DevOps Advocate] Selected answer as best 30th May 2025
José Silva [SLC] [DevOps Enabler] commented 22nd May 2025
Hi Jose,
I noticed you're trying to share some images, but unfortunately, I'm not able to see them on my end. Could you please try uploading them again?
Thanks
Kind regards,
Jose Araujo [DevOps Advocate] commented 22nd May 2025
Hi Jose,
was update with images.
Thanks
Jose
Jose Araujo [DevOps Advocate] commented 24th May 2025
This is resolved using dummy parameter and Actions.
Thanks
Jose Araujo [DevOps Advocate] commented 29th May 2025
Hi Jose,
I fixed this using Param Dummy and set QAction.
thanks
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 30th May 2025 0 Comments
It looks like this question has already been answered in the comments. If this is indeed the case, could you select this answer to indicate that the question can be closed?
