parameter alarm not visible in element card
Solved1.68K views18th July 2023alarm template DVE
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 30th September 2021 0 Comments
With an alarm template on a DVE the DVE element shows the alarm color of some of the parameters, but not of 2 parameters which also have monitoring enabled in the alarm template.
The element shows a critical state, which makes me believe the element sees the alarms, however it can't be seen on the parameter
No conditions are set on the alarm template
Alarm console shows the alarms
The version used is 10.0 CU8
Internally reproducing the issue will be very difficult.
What is the best way to investigate this issue?
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K Posted 1st October 2021 1 Comment
Hi Jeroen,
I see there are normalize actions on your parameter
Could it be that they interfere with the expected behavior? Perhaps you could create a build with these actions removed and see if this overcomes the issue?
Jeroen Geldhof [SLC] [DevOps Enabler] commented 6th October 2021
Hi Timothy,
From what I can see, this is already commented out in the code for the RX DVE.
