Orange Color Node in System Center Failover
738 views28th May 2026
Berman Hsieh249 28th May 2026 0 Comments
When checking the System Center failover configuration, SPSTAPDOCDMWV06 is showing a different color than the other nodes. I don’t recall seeing this previously.
Have you seen this behavior before, or is this something we should look into further?
Brent Alleweireldt [SLC] Answered question 28th May 2026
Brent Alleweireldt [SLC]2.74K Posted 28th May 2026 1 Comment
Hi Berman,
The orange colour gets applied when the agent is "missing", meaning that we cannot get the failover configuration from that agent. The screenshot is a bit contradictory as the status orb is green, it leads me to believe that the colour is a false positive.
A quick check in SLFailover.txt on both agents would be advised to see if there are any errors reported regarding syncing or communicating with each other. If not then the impact will be limited. However if you have concerns feel free to reach out to techsupport for a deeper analysis.
Berman Hsieh Posted new comment 28th May 2026
Berman Hsieh commented 28th May 2026
Thank you, Brent. We will take a look at the SLFailover.txt file.
