OpenSearch – auto_create_index
814 views8th May 2026opensearch
Jan Palansky [DevOps Advocate]262 6th May 2026 0 Comments
I use selfhosted OpenSearch cluster not only for Dataminer and I need to have allowed auto_create_index.
It's not problem to set it and I don't see any problem with Dataminer. But after restart of Dataminer, it change setting to false. So it is possible to say dataminer: Don't touch this settings!
Or do you have any suggestion to have this setting permanent?
thank you in advance.
Wale Oguntoyinbo [SLC] [DevOps Advocate] Answered question 8th May 2026
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.50K Posted 8th May 2026 0 Comments
From what I could gather the persistent cluster wide setting of auto_create_index to "false" on start-up was introduced in RN25461. There could be implications down the line of rolling back this setting. Please get in touch with support@dataminer.services for further advise and to see what options are on the table.
