Once an element is added to a Dataminer system, how can I move the element to a different agent?
Solved1.73K views17th March 2021DMS
Steve Purcell [SLC] [DevOps Advocate]2.63K 12th January 2021 0 Comments
In our Dataminer system we have multiple Dataminer agents across the region installed in different locations.  We have some elements which are added to agents outside of their local Dataminer agent and would like to move these elements to the Dataminer agent in the associated location.  Is there a way to do this without having to remove and re-add the element?
Steve Purcell [SLC] [DevOps Advocate] Selected answer as best 17th March 2021
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 12th January 2021 0 Comments
Hi Steve,
This can be done using the Migrate functionality on the agents page in system center.
You can find a step by step description of how to do this in the DataMiner help.
