Node image in node edge using file path
Solved1.88K views30th May 2024low code apps Node edge graph node-edge
Jonas Kockx [SLC] [DevOps Member]287 30th May 2024 0 Comments
Hi
I would like to use a custom image in my nodes in a Node Edge component in LCA. I’ve tried using a URL link and it worked. However, when I try using a path to a folder, it doesn’t. I’ve tried paths relative to ‘Skyline DataMiner’ folder, relative to Documents folder, etc. How must this path be interpreted?
https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Visualizations/Available_visualizations/Other/Node_edge_graph.html?q=node%20edge
Thanks in advance!
Kind regards,
Jonas Kockx
Jonas Kockx [SLC] [DevOps Member] Selected answer as best 30th May 2024
Wout Mahieu [SLC] [DevOps Catalyst]12.31K Posted 30th May 2024 1 Comment
Hi Jonas,
The path input expects the URL of an image, or a path relative to the C:\Skyline DataMiner\Webpages folder (which is also a url). This means that you can link any public image on the web or an image inside C:\Skyline DataMiner\Webpages.
Jonas Kockx [SLC] [DevOps Member] commented 30th May 2024
Hi Wout, thanks!
