Node Edge with trends
Solved534 views1st July 2025
Juan Falcon439 1st July 2025 0 Comments
Hello
Its posible use a trigger or flow or any component to open a trend when you select a interface on the node edge?
Thanks
Juan Falcon Selected answer as best 1st July 2025
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 1st July 2025 1 Comment
Hi Juan,
Yes, this is possible using these steps
1. Create a new panel with your trend graph.
2. Linking the parameters to your trend graph based on protocol. (Don't add any elements or indices yet).
3. Return to your page with the node edge-component.
4. Make sure you select an edge on your node-edge.
5. Edit the panel containing your trend graph from steps 1 & 2.
6. From the data section on the right, under components, find your node edge and select the relevant feeds (elements and or indices) and drag these onto your trend graph as a filter.
7. Return to your node-edge.
8. Add an action to the edge of your node-edge diagram to open the panel.
The result could then look something like this:
Juan Falcon Posted new comment 1st July 2025
Juan Falcon commented 1st July 2025
Thanks i'll used
