NO AUDIO ON ALARMS
Solved2.09K views11th July 2023
Germanico Canete [DevOps Advocate]56 14th December 2021 0 Comments
Dataminer alerter generates alarm but the sound was not there. Kindly help to fasten the troubleshooting.thanks
Michaël Pincket [SLC] [DevOps Advocate]2.08K Posted 14th December 2021 0 Comments
Hi Germanico,
The clients running Alerter need to have Windows Media Player installed in order to have the sound played. Besides the installation it needs to be opened at least once, so the settings are configured as well. Taking the recommended settings of Windows Media Player is sufficient.
