Nexus 5K supported by Cisco Nexus connector?
Solved1.73K views11th July 2023
Enrique Ugedo [DevOps Advocate]132 21st February 2022 1 Comment
Is Nexus 5K family supported by Cisco Nexus connector?
Randy Ulvenes [SLC] [DevOps Member] commented 24th February 2022
Cisco Nexus 5K family uses the Cisco NX-OS. The Cisco Nexus connector will support this family. If a current parameter is not available, it may be because we have not implemented the specific MIB or OID. Skyline can easily update the connector if required.
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 23rd November 2022 1 Comment
Hi Enrique,
can you confirm that everying is working fine for the Nexus 5K familly?
In case there are still other OIDs that need to be implemented, don’t hesitate to request them via techsupport@skyline.be
Enrique Ugedo [DevOps Advocate] commented 24th November 2022
Hi Marlies,
No complaints from the end user as far as I know, thanks for asking. We will double check and come back to techsupport@skyline.be if required.
