Network Bandwidth for Geographical Redundancy (M&C and SRM)
Solved56.01K views19th July 2023geographical redundancy Network Bandwidth
Naveendran Murthy [SLC] [DevOps Member]226 2nd March 2021 2 Comments
What will be the network bandwidth required in between a geographically redundant  1+1 DMA-E500 setup (as per the attached diagram), managing M&C works for broadcast downlink, MCR and compression along with a max of 20 concurrent SRM booking with resources from both sites?
I've checked the answers from the link below and am still in need of more details to match the above elaborated scenario in order to have an acceptable justification for the required bandwidth.
Network bandwidth required
Ben Vandenberghe [SLC] [DevOps Advocate] commented 2nd March 2021
Just to clarify, you have one DMA-500 on the main site, and a hot backup on the backup site? Or is there a DMA-500 on each site, with each of them have a redundant counterpart on the other site? Because I got a little confused about the statement “with resources from both sites”.
Naveendran Murthy [SLC] [DevOps Member] commented 2nd March 2021
Yes Ben, we will have one DMA-500 on the main site, and a hot backup on the backup site. By resources, I was refering to the resources within SRM service workflow that will be manageable by DM.
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 3rd March 2021 2 Comments
Further to the earlier response, where we established that 500kbps would be a good baseline for the inter-node and client traffic.
Now we have to add the data stream to collect data from 250 devices as well.  Again, this really depends on which devices and what type of protocol they use.  Devices feature all kinds of interfaces, ranging from quite bandwidth efficient binary (usually proprietary) protocols, to standard SNMP, or HTTP / XML / JSON type of exchanges.
We'll have to make assumptions.  So let's assume SNMP.  Then it still depends on details such as whether or not the device supports bulk getting metrics, or if you have to fetch each metric individually.   And then of course also how many metrics there are, how fast you want to update those, etc.  Below you can find a quick example: 250 devices, getting 50 metrics each 5 seconds, 100 metrics each 60 seconds (the less critical data), and another 100 metrics each 3600 seconds.  That amounts to about 2.3 Mbps.  This would have to be added to the 0.5 Mbps that we already defined.
I'll ask to add the Excel to Dojo and to give you a link, just in case you want to play with it.  It's a basic model, but at least gives you something to go by.
Note: DataMiner also has a timer base control, which you can use to dynamically accelerate or decelerate the polling.  You could easily add a rule that for example slows down the polling, and ramps it up when a device is in an alarm state.  Not sure if that would be needed, because I guess that depends on how expensive that inter-site connection is for you.
I know this is not an exact response, but there are many variables here that we don't know, so this is the best we can do for now.
Rahimi Mohd Dalim [DevOps Member] Posted new comment 8th March 2021
Marieke Goethals [SLC] [DevOps Catalyst] commented 3rd March 2021
You can now find this Excel file here: https://community.dataminer.services/documentation/snmp-bandwidth-estimation-tool/
Rahimi Mohd Dalim [DevOps Member] commented 8th March 2021
Thanks Ben. I believe this information is sufficient for me to move forward for now. It is also amazing to see how light the BW requirements can be for such a large setup, given the assumed polling conditions. I’ll use the provided excel sheet to estimate our need. Thanks Marieke for the link!
