Need to merge multi alarms into a single alarm
Solved771 views27th June 2025
Ramesh Rajasekaran [DevOps Member]787 28th March 2025 0 Comments
Hello Team,
We have multi alarms with the same value for the same service but for different devices. Rather than having multi alarms. I would like to show only one alarm. I don't want the to group the alarms. But need only on alarm instead of 4 alarms in this case.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Bram Devlaminck [SLC] [DevOps Enabler]922 Posted 31st March 2025 0 Comments
Hi Ramesh,
You should be able to achieve this with a combination of a correlation rule that groups the alarms per service, and then an automation script to do the actual "combining" into a new alarm that is generated from the automation script.
The "base" alarms can from there be acknowledged to only show the new "combined" alarm.
More information can be found here: https://docs.dataminer.services/user-guide/Advanced_Modules/Correlation/Adding_rule_actions/Running_an_Automation_script_from_a_Correlation_rule.html
Hope this gives you a rough idea on how to proceed.
Kind regards,
