NATS issues when starting DM for the first time after startup
Solved2.68K views20th May 2024elements NATS startup
Edib Šupić [SLC] [DevOps Enabler]2.55K 7th January 2024 0 Comments
I've been having an issue when starting up DM after system startup for the first time, every time I have to restart DM in order for it to startup properly. The first time I start DM after system startup my elements do not load and I can see the following exceptions in SLErrors:
2024/01/07 18:51:35.271|SLServiceManager.txt|SLNet.exe|Initialize|ERR|0|49|Exception occurred while initializing ServiceManager.
Exception occurred: (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Sending SLDataGateway message request:Skyline.DataMiner.Net.Messages.SLDataGateway.GetDataFromConfigFileRequest over NATS failed with error: DataMinerMessageBroker.API.Exceptions.SubscriptionException: No responders are available for the request. ---> NATS.Client.NATSNoRespondersException: No responders are available for the request.
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at NATS.Client.Connection.<RequestAsyncImpl>d__147.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at DataMinerMessageBroker.API.Nats.NatsSession.<RequestAsync>d__28.MoveNext()
   at DataMinerMessageBroker.API.MessageBroker.<RequestAsync>d__18.MoveNext()
   at DataMinerMessageBroker.API.Chunking.ChunkingMessageBroker.SendChunkAcked(String subject, Byte[] bytes, Int32 length, Int32 chunkID)
   at DataMinerMessageBroker.API.Chunking.ChunkGenerator.SendMessage(String subject, Int64 responseId, Stream data, Boolean bNeedsAck, ChunkHandler handler)
   at DataMinerMessageBroker.API.Chunking.ChunkGenerator.Request(String subject, Int64 responseId, Byte[] bytes, Int32 length)
   at DataMinerMessageBroker.API.Chunking.ChunkingMessageBroker.<RequestAsync>d__36.MoveNext()
   at DataMinerMessageBroker.API.Chunking.ChunkingMessageBroker.<RequestAsync>d__39.MoveNext()
   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
   at Skyline.DataMiner.Net.SLDataGateway.DataGateway.SendMessage[TReq,TResp](TReq request, String method, Nullable`1 timeout)
   at Skyline.DataMiner.Net.SLDataGateway.DataGateway.ExecuteRequest(BaseRequest request)
   at Skyline.DataMiner.Net.Facade.HandleClientRequestMessage(IConnectionInfo connInfo, ClientRequestMessage oneMsg, Boolean canQueue)
   at Skyline.DataMiner.Net.Facade.HandleMessageInternal(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
   at Skyline.DataMiner.Net.Facade.HandleMessage(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
   at Skyline.DataMiner.Net.BaseFacade.HandleMessage(DMSMessage oneMsg)
   at Skyline.DataMiner.Net.CacheManager.CacheLocalDatabaseInfo()
   at Skyline.DataMiner.Net.CacheManager.get__cachedLocalDatabaseInfo()
   at Skyline.DataMiner.Net.CacheManager.get_HasSearch()
   at Skyline.DataMiner.Net.ServiceManager.ServiceManager.Initialize()
This error is followed up by the following exception, however I think the first one causes the subsequent exceptions:
2024/01/07 18:51:35.285|SLResourceManager.txt|SLNet.exe|ResourceManager|ERR|0|70|[Attempt 1/5] Exception while initializing ResourceManager.
What I find weird is that these exceptions occur only on the first time I startup my DM, after the restart the errors get resolved. My DM doesn't startup automatically, I purposely start it up manually, so I don't think the issue can be related to certain parts of the system not loading in time. Since it seems that issue is related to NATS, I have tried these steps with no avail. Could it be that because I have disabled automatic DM startup that NATS doesn't start up on it's own, although I'm not sure why DM would be able to start before NATS start anyhow. Any ideas of how I might fix this?
I'm using DM 10.4.0
Thanks,
Edib
Edib Šupić [SLC] [DevOps Enabler] Selected answer as best 20th May 2024
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 8th January 2024 0 Comments
I've been able to resolve this issue.
  1. Remove NAS and NATS by going to Registry-> HKEY_LOCAL‌​_MACHINE-> System-> Cur‌​rentControlSet-> Servi‌​ces and deleting NAS and NATS folders.
  2. Reboot
  3. Install NAS and NATS by following these steps.
Hope this helps someone else as well.
Cheers
Edib Šupić [SLC] [DevOps Enabler] Unselected an answer 20th May 2024
