NATS & IPC: what info is exchanged via NATS in a cluster (DM 10.x – and on)?
Solved2.27K views3rd February 2025adl20299 IPC NATS SLNet
Alberto De Luca [DevOps Enabler]5.73K 21st June 2024 2 Comments
I seem to recall since DM10, specific ports became required in a cluster for the usage of NATS.
What info is actually exchanged via the NATS service?
What is still relying on SLNet instead?
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 3rd February 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd November 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 27th August 2024 0 Comments
Hi Alberto,
I've checked with the Data Core team, and it appears that NATS is used for too many things to easily be able to enumerate this here. However, the most important ones are DxM communication, parameter changes, and alarms. Laurens also provided some more information about this here: https://community.dataminer.services/question/nats-service-ipc-is-it-actually-required-in-a-cluster/
