Monitoring Dell network switches
Solved973 views11th September 2025Dell network switches
Laszlo Szabados [DevOps Advocate]304 29th April 2025 0 Comments
Does anyone have experience with monitoring Dell network switches with DataMiner, specifically Dell N3224T-ON, Dell N3248TE-ON and Dell S4148F-ON models?
I couldn’t find a corresponding driver in the Catalog for them.
Thank you.
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 29th April 2025 0 Comments
Hi Laszlo,
I had a quick look and I could find this connector in the catalog:
Dell MXL 10-40 GBE Switch
This connector implements a few OIDs from Dell’s MIB (1.3.6.1.4.1.674, 1.3.6.1.4.1.6027). Apart from the SNMP polling, this connector polls information information via SSH.
You could give a try to this connector.
Hope it helps.
