Missing a using directive or assembly reference? on newly added DMA in DMS
Solved3.51K views12th September 2023
Koen Bouckhout [SLC] [DevOps Advocate]1.68K 12th September 2023 0 Comments
Dear community,
I installed a new DMA and added it to an existing DMS Cluster (running 10.1.12). After initial syncing,  I added the first elements (HP ilo) on the new DMA but I see the below errors in the element log.  Looks like the DMA is missing some references.  May some files are not correctly sync'ed within the DMS yet?
Any clue what is missing and how to fix?
Thanks,
Koen.
(15,8): error CS0246: The type or namespace name 'Newtonsoft' could not be found (are you missing a using directive or an assembly reference?)
(2418,8): error CS0246: The type or namespace name 'Newtonsoft' could not be found (are you missing a using directive or an assembly reference?)
(7016,8): error CS0246: The type or namespace name 'Newtonsoft' could not be found (are you missing a using directive or an assembly reference?)
(2935,7): error CS0246: The type or namespace name 'JsonPropertyAttribute' could not be found (are you missing a using directive or an assembly reference?)
(2935,7): error CS0246: The type or namespace name 'JsonProperty' could not be found (are you missing a using directive or an assembly reference?)
(2942,7): error CS0246: The type or namespace name 'JsonPropertyAttribute' could not be found (are you missing a using directive or an assembly reference?)
(136,109): error CS0103: The name 'Constants' does not exist in the current context
(136,132): error CS0103: The name 'Constants' does not exist in the current context
2023/09/12 21:13:29.959|SLManagedScripting.exe|ManagedInterop|ERR|-1|10|No CodeBuilder found (element 7616/2 trigger 102 cookie 0)
2023/09/12 21:13:29.959|SLProtocol - 14144 - TS40G-VOS-EXP-Clus09-Ctr01 iLO|20504|CQAction::Run|ERR|-1|QAction [2000] triggered by [pid=102/idx=-1/pk=/user=] failed. (0x80040221)
Input: new = <NULL>
Input: old = <NULL>
Input: extra = <NULL>
2023/09/12 21:13:30.853|SLProtocol - 14144 - TS40G-VOS-EXP-Clus09-Ctr01 iLO|18556|CManagedScript::Load|ERR|-1|Compilation failed for QAction 1000
(6,7): error CS0246: The type or namespace name 'HPILOGen10' could not be found (are you missing a using directive or an assembly reference?)
(7,7): error CS0246: The type or namespace name 'HPILOGen10' could not be found (are you missing a using directive or an assembly reference?)
Koen Bouckhout [SLC] [DevOps Advocate] Selected answer as best 12th September 2023
Pedro Debevere [SLC] [DevOps Enabler]3.46K Posted 12th September 2023 0 Comments
In DataMiner 10.3.8, a fix was done so that the ProtocolScripts\DllImport folder will also be synced when an Agent joins the cluster (see this release note).
Like Tom mentions, you'll need to put the assemblies used by the connector on the Agent as these will not have been synced.
