Metric spikes counter
Solved1.65K views19th June 2025alarm alerts metrics
Shaddad Gomid42 19th December 2024 0 Comments
I'm looking for an option that sends an alert in case a specific metric reaches a certain number of spikes beyond the threshold in a certain amount of time.
For example:
CPU usage threshold is 70%, beyond that the severity is critical.
In order not to get flooded with alerts (I'm aware of storm prevention though), I'm looking to configure that an alert will kick-in in case the metric value exceeded the threshold 5 times in 1 minute. I haven't found such option while using the platform.
I would appreciate your assistance,
Shaddad.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th June 2025
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 19th December 2024 0 Comments
When I find the time (or maybe someone else will do so), I will work this specific one out for myself.
For now though, I want to make you aware of Correlation as the preferred DM functionality for this.
The documentation should set you well on your way to configure something like this for yourself.
Toon Casteele [SLC] [DevOps Enabler] Answered question 19th December 2024
