Metric spikes counter
Solved1.66K views19th June 2025alarm alerts metrics
Shaddad Gomid42 19th December 2024 0 Comments
I’m looking for an option that sends an alert in case a specific metric reaches a certain number of spikes beyond the threshold in a certain amount of time.
For example:
CPU usage threshold is 70%, beyond that the severity is critical.
In order not to get flooded with alerts (I’m aware of storm prevention though), I’m looking to configure that an alert will kick-in in case the metric value exceeded the threshold 5 times in 1 minute. I haven’t found such option while using the platform.
I would appreciate your assistance,
Shaddad.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th June 2025
Leander Druwel [SLC] [DevOps Member]2.10K Posted 20th December 2024 0 Comments
Hi Shaddad,
As Toon mentions, the correlation engine is an excellent option for counting events and triggering or escalating an alarm when the number of occurrences exceeds a predefined threshold.
Then again, for this specific use case of alarming on CPU, we typically apply a hysterises into the alarm template. As you might not necessarily want to alarm when the CPU is just 5 times exceeding a limit, the use case could be that you want to be alerted if the CPU is high for a longer period of time, without any drops. That might indicate a process that is continuously running high.
So, another possibility is to put a hysteresis of e.g. 60 seconds to the CPU parameter. Only if the CPU keeps on running high for a minute or more, the alarm would be generated.
More information can be found on
Configuring hysteresis in an alarm template | DataMiner Docs
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 19th December 2024 0 Comments
When I find the time (or maybe someone else will do so), I will work this specific one out for myself.
For now though, I want to make you aware of Correlation as the preferred DM functionality for this.
The documentation should set you well on your way to configure something like this for yourself.
Toon Casteele [SLC] [DevOps Enabler] Answered question 19th December 2024
