Meinberg NMS installation
Solved4.01K views12th July 2023
Kestutis Rokas77 11th November 2022 0 Comments
Hello,
I'm installing NMS system and got stuck at stage where you need to execute "Meinberg_SetupWizard".  After entering all the data wizard is asking I got:
System center logging section revealing some more info:
----------- LogID: 199 -----------
Warning
ServerTime: 2022-11-11 17:31:34
ClientTime: 2022-11-11 17:31:36
Message : Automation script 'Meinberg_SetupWizard' failed to execute (ScriptErrorType: ErrorType) : EXIT: "AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
(Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript 'Meinberg_SetupWizard_Run' Failed: 0x80004005
at Skyline.DataMiner.Automation.Engine.InternalLaunchSubScript(String scriptName, List`1 finalOptions, Int32 inheritSubScript, Dictionary`2& subScriptOutput)
at Skyline.DataMiner.Automation.SubScriptOptions.StartScript()
at Script.RunSafe(Engine engine)
at Script.Run(Engine engine)".
Exception: EXIT: "AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
Data miner version 10.2. Meinberg NMS app version 1.1.0. (tried version 1.1.1 also).
Can I get some help?
Stijn Declerck [SLC] [DevOps Advocate]834 Posted 14th November 2022 0 Comments
Hi Kestutis,
Based on the error in the logging you provided, it is possible the automation script 'Meinberg_SetupWizard_Run' is missing. Could you send us an image of the available automation scripts under the folder "Automation scripts">"Meinberg Solution">"Setup Wizard". So, Is the marked automation script in the image below available on your system?
If the script is available, it will probably at run time and we will need more information to investigate te issue.
You are viewing 1 out of 5 answers, click here to view all answers.
