Meinberg NMS installation
Solved3.69K views12th July 2023
Kestutis Rokas77 11th November 2022 0 Comments
Hello,
I'm installing NMS system and got stuck at stage where you need to execute "Meinberg_SetupWizard".  After entering all the data wizard is asking I got:
System center logging section revealing some more info:
----------- LogID: 199 -----------
Warning
ServerTime: 2022-11-11 17:31:34
ClientTime: 2022-11-11 17:31:36
Message : Automation script 'Meinberg_SetupWizard' failed to execute (ScriptErrorType: ErrorType) : EXIT: "AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
(Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript 'Meinberg_SetupWizard_Run' Failed: 0x80004005
at Skyline.DataMiner.Automation.Engine.InternalLaunchSubScript(String scriptName, List`1 finalOptions, Int32 inheritSubScript, Dictionary`2& subScriptOutput)
at Skyline.DataMiner.Automation.SubScriptOptions.StartScript()
at Script.RunSafe(Engine engine)
at Script.Run(Engine engine)".
Exception: EXIT: "AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
Data miner version 10.2. Meinberg NMS app version 1.1.0. (tried version 1.1.1 also).
Can I get some help?
Thomas Gunkel [SLC] [DevOps Enabler]1.24K Posted 12th November 2022 0 Comments
Dear Kestutis,
it is difficult to say what exactly went wrong here, just to double check: did you download the latest manual REV009 and follow exactly the steps described in 1.1.2 and 1.1.3? We have seen similar issues when DataMiner was not installed correctly, e.g. Cassandra-database missing or something similar
SLC_UM_Meinberg_NMS_REV009.pdf - DataMiner Dojo
You should run the latest 1.1.1 Meinberg Manager app together with 10.2.0 DataMiner.
Thomas Gunkel [SLC] [DevOps Enabler] Answered question 12th November 2022
You are viewing 1 out of 5 answers, click here to view all answers.
