Meinberg NMS installation
Solved2.87K views12th July 2023
Kestutis Rokas77 11th November 2022 0 Comments
Hello,
I’m installing NMS system and got stuck at stage where you need to execute “Meinberg_SetupWizard”.  After entering all the data wizard is asking I got:
System center logging section revealing some more info:
———– LogID: 199 ———–
Warning
ServerTime: 2022-11-11 17:31:34
ClientTime: 2022-11-11 17:31:36
Message : Automation script ‘Meinberg_SetupWizard’ failed to execute (ScriptErrorType: ErrorType) : EXIT: “AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
(Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript ‘Meinberg_SetupWizard_Run’ Failed: 0x80004005
at Skyline.DataMiner.Automation.Engine.InternalLaunchSubScript(String scriptName, List`1 finalOptions, Int32 inheritSubScript, Dictionary`2& subScriptOutput)
at Skyline.DataMiner.Automation.SubScriptOptions.StartScript()
at Script.RunSafe(Engine engine)
at Script.Run(Engine engine)”.
Exception: EXIT: “AS [Meinberg_SetupWizard] Error| Message: Unexpected error:
Data miner version 10.2. Meinberg NMS app version 1.1.0. (tried version 1.1.1 also).
Can I get some help?
Stijn Declerck [SLC] [DevOps Advocate]802 Posted 14th November 2022 0 Comments
Hi Kestutis,
Based on the error in the logging you provided, it is possible the automation script ‘Meinberg_SetupWizard_Run’ is missing. Could you send us an image of the available automation scripts under the folder “Automation scripts”>”Meinberg Solution”>”Setup Wizard”. So, Is the marked automation script in the image below available on your system?
If the script is available, it will probably at run time and we will need more information to investigate te issue.
Kestutis Rokas77 Posted 14th November 2022 0 Comments
Hi Stijn,
here is the picture of automation scripts:
Not sure why version in desciption is older than installed?!
Kestutis Rokas Answered question 14th November 2022
Yes, step by step.
The only step that concerns me is about administrator right. I was given a user type “Administrator”:
Is it enough for installation?
Dear Thomas,
I can assure you that we used latest version software from dataminer site: 10.2.0 with 1.1.1 Meinberg APP version. And installed everything multiple times. By the way virtual server OS is Win Server 2016. Step by step using Meinberg manual REV009.
Maybe I could post some more log’s I don’t know about to clear thing up?
Thomas Gunkel [SLC] [DevOps Enabler]1.23K Posted 12th November 2022 0 Comments
Dear Kestutis,
it is difficult to say what exactly went wrong here, just to double check: did you download the latest manual REV009 and follow exactly the steps described in 1.1.2 and 1.1.3? We have seen similar issues when DataMiner was not installed correctly, e.g. Cassandra-database missing or something similar
SLC_UM_Meinberg_NMS_REV009.pdf – DataMiner Dojo
You should run the latest 1.1.1 Meinberg Manager app together with 10.2.0 DataMiner.
Thomas Gunkel [SLC] [DevOps Enabler] Answered question 12th November 2022
