Masking future alarms for a specified EPM object from an Automation script
499 views20th February 2026#EPM #Masking #Alarms #API
Alexandre Lievens [DevOps Member]283 10th September 2025 1 Comment
Hi everyone,
i'am looling to mask an EPM object from a c# automation script similar to the UI option that masks the object so that all related alarms (including new ones from the object itself and the children) are masked. The idea is to provide the EPM object by its System Type and System Name, a duration and the masking option.
Can you help me with that ?
Thanks a lot!
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 20th February 2026
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the most relevant answer (using the ✓ icon) to indicate that no further follow-up is needed?
Pieter Van Compernolle [SLC] [DevOps Enabler]3.81K Posted 23rd September 2025 0 Comments
Hi Alexandre,
Here's an automation script that should more or less do the job for you, hope this helps
using System;
using Skyline.DataMiner.Net;
using Skyline.DataMiner.Net.Masking;
using Skyline.DataMiner.Net.CPE;
internal class Script
private Engine _engine;
private const string SCRIPT_NAME = "Mask EPM";
private String _systemType;
private String _systemName;
private bool _mask = true;
_engine = engine;
try
_systemType = _engine.GetScriptParam("System Type").Value;
_systemName = _engine.GetScriptParam("System Name").Value;
if (!bool.TryParse(_engine.GetScriptParam("Mask").Value, out _mask)
_engine.GenerateInformation($"'{SCRIPT_NAME}' - Could not parse mask bool from Parameters");
Masking.InitMasking(engine);
Masking.SetMaskedStateForEPM(engine.UserDisplayName, _mask,_systemType, _systemName);
catch (Exception e)
_engine.GenerateInformation($"'{SCRIPT_NAME}' - " + e.ToString());
public static class Masking
private static CPECollectorHelper _helper;
public static void InitMasking(Engine engine){
_helper= new CPECollectorHelper(Engine.SLNetRaw);
public static void SetMaskedStateForEPM(String user, bool mask, String systemType, String systemName)
_helper.MaskLinkedDMAObjectRefTreesThroughTopology(
new MaskInfo()
DoMask = mask,
MaskType = MaskType.UntilUnmask,
Reason = "masking test"
systemType,
systemName
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 23rd September 2025
