Masking Alarms Delay Using SLNet Message
Solved1.39K views31st January 2025Masking SLNet
Geovanny Galeano [SLC] [DevOps Advocate]820 18th September 2024 3 Comments
I have a manager connector which mask alarms for services not on air. We are seeing some delays in the masking sometimes between 2-4 minutes to mask one single alarm for an element that can be found in about 3 services max.
This is the request
// mask alarm
var info = new SLNetMessages.SA
Sa = new[] { "-1", "Masking critical alarm for service " + serviceName + " since it is not currently on air." },
var message = new SLNetMessages.SetAlarmStateMessage
AlarmId = alarmId,
DataMinerID = dmaId,
HostingDataMinerID = dmaId,
ElementID = elementId,
Info = info,
State = Convert.ToInt32(AlarmState.Mask),
Value = String.Empty,
protocol.Log($"QA{protocol.QActionID}|About to send SLNET|Right before sending {DateTime.Now}", LogType.Information, LogLevel.NoLogging);
var response = protocol.SLNet.SendSingleResponseMessage(message) as SLNetMessages.SetAlarmStateMessage;
The delay happens at the moment of sending the request. I have a log right before sending the request message and one after the response and we are getting the 2-4 minutes to mask this alarm.
Is there a way to follow the request or check why it takes so long?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 31st January 2025
Joey Vanhalst [SLC] [DevOps Advocate] commented 19th September 2024
Hi Geovanny, I would expect the same behavior when masking alarms directly from the Alarm Console. Do you also see the same delay there?
Geovanny Galeano [SLC] [DevOps Advocate] commented 27th September 2024
Both from cube and using the client test tool the operation took less than a second, so for sure there is something wrong with the driver. I’m currently investigating after taking a look at the pending calls.
Thanks,
Geovanny Galeano [SLC] [DevOps Advocate] commented 30th January 2025
Issue was fixed by using a new protocol name and element. There was something external slowing down the original element.
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 31st January 2025 0 Comments
It looks like this question has already been answered in the comments. To make it clear that this question no longer requires an answer, I have added this pro forma answer so that we can mark it as resolved.
