Masked alarmes permission management
Solved698 views11th September 2025mask permissions
Simon Nenez [DevOps Advocate]756 12th May 2025 0 Comments
Dear Dojo,
I want to allow, using group permissions, the access to “Mask this alarm only” but not “Mask this Equipment”. Is it possible to define that using the Users/Groups permissions menu ?
Thanks for your help
Miguel Obregon [SLC] [DevOps Catalyst]22.41K Posted 13th May 2025 0 Comments
Hi Simon,
You could use the following group setting:
For elements:
For alarms:
You will still be able to see the option to mask the element. However, the masking options will be greyed out.
Hope it helps.
