Mask & Unmask alarms by element or view
Solved1.64K views26th March 2024maskalarms
André Camões [SLC] [DevOps Advocate]575 25th March 2024 0 Comments
Hello community,
I need to mask alarms either for a specific element or for a view. I would like to ask if anyone happens to have a solution, either through a Low Code App, interactive AS or a dashboard, to speed up the development of what I’m looking for.
Thank you.
André Camões [SLC] [DevOps Advocate] Selected answer as best 25th March 2024
Hugo Andrade [SLC] [DevOps Member]213 Posted 25th March 2024 3 Comments
Hi André,
Here you can find what you are looking for:
https://catalog.dataminer.services/details/package/5972
In this package you can find a script and a low-code app that not only allows you to mask alarms by element and view but also by service.
Hope that helps! 😉
Thijs Vanovenacker [SLC] [DevOps Advocate] Posted new comment 29th June 2026
André Camões [SLC] [DevOps Advocate] commented 25th March 2024
Great! Thanks Hugo
Ben Vandenberghe [SLC] [DevOps Advocate] commented 25th March 2024
Brilliant response. The answer in a package 🙂
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 29th June 2026
I was also looking for similar info. Looks like the link no longer works: I assume this is the package: https://catalog.dataminer.services/details/220cda2d-7c41-46f8-a38b-85264c05e771
