Manually adding Cisco Switch Port on element
Solved1.35K views15th February 2024Cisco Switch Port
Hugo Landrey28 15th February 2024 5 Comments
We are trying to add a port in the element we have for our Cisco Switch to monitor a specific port (Gi5/17). We assumed that it automatically pulled SNMP from the cisco and would recognise that port Gi5/17 with a bitrate and would be displayed in the element for RX and TX but it isn’t displaying it as shown below;
Is there a way of manually adding the port to the element or is there an SNMP setting we have to activate or restart for it to automatically detect and display the specific port?
Regards,
Hugo
Hugo Landrey Selected answer as best 15th February 2024
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 15th February 2024
What connector are you using ?
Hugo Landrey commented 15th February 2024
Hi, are you referring the connection from the dataminer to the switch?
Miguel Obregon [SLC] [DevOps Catalyst] commented 15th February 2024
Hi Hugo,
Wale is referring to the driver that you are using to monitor the Cisco switch.
I am refering to the dataminer driver (protocol) that your element is using.
Cisco Manager Version: Production 5.1.6.19
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.03K Posted 15th February 2024 1 Comment
There is a ‘Measurement Configuration’ page that lists all detected interfaces. On this page you can enable or disable the monitoring of interfaces. Enabling an interface will make it available for monitoring and be dispalyed on the Rx / Tx tables.  You can find more details in the Cisco Manager driver help page
That did it, thanks for the help Wale!
