Low-Code Apps – Filter state component based on display key.
172 views12th March 2026low code app state component
Ive Herreman [SLC] [DevOps Enabler]14.55K 12th March 2026 2 Comments
Is there a way to filter which rows from a table are displayed in a state component using the display key?
I noticed that filtering by indices is possible, but those indices can change over time.
Ideally, I would like to filter based on the display key instead. Is that supported?
Thanks!
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 12th March 2026
Wout Mahieu [SLC] [DevOps Catalyst] commented 12th March 2026
Hi Ive,
Can you add some more info about the data that is used in the state component? Is it a Query, Variable, Flow, coming from a different component, … ?
Ive Herreman [SLC] [DevOps Enabler] commented 12th March 2026
Hi Wout,
The component is linked to a Parameters – from > protocol > table > column.
P.S.
I don't believe it's possible to feed the state component with a query.
Wout Mahieu [SLC] [DevOps Catalyst]11.50K Posted 12th March 2026 0 Comments
Hi Ive,
A State component that has Parameter data can only have an Index and/or Element as filter (depending on the parameter type). It isn't possible to filter on the display key.
Alternatively, it is possible to fetch this data using a query and use that in the state component. Note that this means the updates work differently and you loose the alarm state indicator.
