Low Code Apps; Automation Scripts with Variables; Options in how to model the parameterdata?
Solved1.97K views6th July 2023low code apps
8
Jan Piet Ballegeer [DevOps Advocate]344 5th April 2023 0 Comments
Hi; Let me jump in the immediate use case here.
I have a list of channels to select from in low code apps; I have a feed which shows me the multicast
feedA: 239.1.1.11:1234
The expected parameter input is: udp://239.1.1.11:1234
how do I combine a set string with a feed in the low code apps option?
I was hoping to do something as "userdefinableText"+"FeedValue"
but I do not seem to be able to combine items; or is there another option somehwere?
Use case: select stb; press the "select TV channel" button
select channel and press Retune STB.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 14th April 2023 0 Comments
Hi Jan Piet,
The easiest solution is probably to adjust your script so that it reads in the value as is and prepends the 'udp://' text to the value. You could make it conditional so this only happens when the 'udp://' prefix is not already available.
If this were not possible then I currently only see a solution in GQI. With GQI you can transform your parameters in any way. For this case you could use a 'Column manipulation' of type 'Concat' using the following format 'udp://{0}'. The GQI visualizations expose a 'Query rows' feed which represents the selection. You can access the cell of a row by providing the correct column name in the feed configuration.
