Low Code Apps; Automation Script; feature request: Dummy as a feed
Solved1.07K views6th July 2023low code apps
10
Jan Piet Ballegeer [DevOps Advocate]332 5th April 2023 1 Comment
Hi; in our low code app; When I make a selection from a list of elements; the specific parameters are shown for the element; but I want to start an automation script which is executed on the selected element in Low Code apps.
I was planning to use a feed; but I do not see the option in our version; is this available in a future version already? current version 10.2.10.0
Use case: select stb from list and press "Select TV Channel"
Popup Opens;
Select desired Channel and Press "retune STB to Selected Channel"
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 14th April 2023
During Empower you showed me that the selection from the table was immediately cleared. Could we perhaps be impacted by the same problem here? I just tested this on a local setup and I’m not able to reproduce it.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 17th April 2023 0 Comments
Hi Jan Piet,
Could we arrange a brief meeting to examine where things may be going wrong with your use case? Our team is keen to ensure that your use case is operational, and we could also offer some suggestions for further enhancements. Is this acceptable to you?
