Low Code App – Use grid component for node-edge highlight
Solved1.09K views12th February 2025grid component low code app node-edge nodeedgeGraph
Ive Herreman [SLC] [DevOps Enabler]14.79K 12th February 2025 0 Comments
Hi Community,
I’m currently using the query filter component to highlight paths in the node-edge component of my low-code application.
However, I’d like more control over the UI, and I see that the grid component offers a lot of flexibility.
Can I achieve the same highlighting effect with the grid component as I can with the query filter?
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 12th February 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.34K Posted 12th February 2025 0 Comments
Hi Ive,
This is not possible. The highlighting in the Node-edge component is based on Query column data that is linked to the filter of the component. It is not possible to expose such data from a grid component.
