Low code App – Setting Parameters
Solved1.69K views5th July 2023
john watt94 11th May 2023 0 Comments
Am I correct in my understanding that
  1.  It is not possible to set DM parameters directly (only using scripts)
  2. Only object manager instances can edited in the Low Code apps
Gilles Bara [SLC] [DevOps Advocate]7.27K Posted 15th May 2023 3 Comments
Regarding setting parameters:
Launching a script is indeed one way to set a parameter. Another way, allthough with its limitations, is through the parameter page component.
The disadvantage of this approach is that
  1. The parameter needs to be available on a page
  2. You’ll end up with th entire page, while you probably want to modify a single parameter.
There are (short term) plans however to have a dedicated component for this, available both in dashboards and Low Code Apps!
For now, you could create your own by combining a text/number feed with some buttons linked to a script. You could link the script to the feeds in order to dynamically change a selected parameter.
This workaround is only possible in Low Code Apps, as it relies on the button component. (Having this available in dashboards could be done with the Grid component)
Regarding the object manager instances
You are correct that the create and update capabilities are scoped to Low Code Apps only. This grew from the idea that dashboards are all about displaying data, while Low Code Apps is about doing something/anything with data.
Lately, we’re stepping away from this initial idea and the edit capabilities will eventually also reach dashboards.
Nils Hoven [DevOps Advocate] Posted new comment 4th March 2024
Nils Hoven [DevOps Advocate] commented 1st March 2024
Hi Gilles,
since we have the same question as John has had, I wondered if in the meantime there is a solution for this at hand, so that we are able to set simple parameters via a low-code app (and don’t need to build automation scripts for that).
Any news? Thank you! 🙂
Gilles Bara [SLC] [DevOps Advocate] commented 1st March 2024
Hi Nils, there were no features added regarding setting a parameter. As far as I know the above solution is still the only way to do it in LCA.
Nils Hoven [DevOps Advocate] commented 4th March 2024
Hi Gilles,
okay, thank you!
BR
Nils
