Low code app not executing asking to execute automation, but execute tab not highlighted
Solved485 views29th October 2025
Sachin Joshi [DevOps Member]108 28th October 2025 0 Comments
Created an automation script and make a low code app, after a button is pressed to launch the script on low code app a pop up arises asking to execute the app, but the pop-up button is not allowing to click to execute. both script and low code app has administrator rights having edit option
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th October 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 28th October 2025 1 Comment
Hi Sachin,
Is this the popup you're seeing?
In case it is, it's because there are parameters that require a value before being able to execute the script.
Sachin Joshi [DevOps Member] Posted new comment 28th October 2025
Sachin Joshi [DevOps Member] commented 28th October 2025
Thanks. It was due to memory files. Now resolved.
