Low Code App – IAS Layout Shift
Solved2.08K views5th January 2023IAS low code app low code apps
Blake Smethers [SLC] [DevOps Advocate]1.21K 3rd January 2023 3 Comments
I’m using an automation script to schedule a planned outage on a device with a custom made interactive automation script. In Cube, the IAS looks fine:
When I use a low code app however, it seems the layout of the remove button is skewed:
Is there a setting to fix this? Any help is appreciated, thanks.
Joey Vanhalst [SLC] [DevOps Advocate] Posted new comment 5th January 2023
Lander Vanhaverbeke [SLC] [DevOps Member] commented 4th January 2023
Hey, can you give some more info on the layout you’re using? On which column is that button, how are the column widths configured, etc.
Blake Smethers [SLC] [DevOps Advocate] commented 4th January 2023
Hi Lander, I’m setting up the Screen like below:
UIBuilder uib = new UIBuilder();
uib.RequireResponse = true;
uib.ColumnDefs = “a;a;a”;
uib.RowDefs = “a;a;a;a;a;a;a;a;a”;
uib.Width = 700;
uib.Height = 600;
uib.AppendBlock(StaticText(“OutageNameLabel”, OutageNameLabel, 0, 1, 0, 1, 150, 30));
uib.AppendBlock(TextBox(“OutageName”, 0, 1, 1, 1, 200, 30, OutageName));
uib.AppendBlock(StaticText(“StartDateLabel”, StartDateLabel, 1, 1, 0, 1, 100, 30));
uib.AppendBlock(Calendar(“StartDateSelection”, 1, 1, 1, 1, 200, 30));
uib.AppendBlock(StaticText(“EndDateLabel”, EndDateLabel, 2, 1, 0, 1, 100, 30));
uib.AppendBlock(Calendar(“EndDateSelection”, 2, 1, 1, 1, 200, 30));
uib.AppendBlock(StaticText(“FilterLabel”, FilterLabel, 3, 1, 0, 1, 100, 30));
uib.AppendBlock(FilterBox(“FilterSelection”, 3, 1, 1, 1, 200, 30, FilterSelection));
uib.AppendBlock(StaticText(“SelectChannelsLabel”, SelectChannelsLabel, 4, 1, 0, 2, 300, 30));
uib.AppendBlock(CheckBoxList(“ChannelNameChecks”, 5, 3, 0, 1, 200, 300, false, ChannelNames));
uib.AppendBlock(Button(“AddButton”, AddButton, 5, 1, 1, 1, 100, 30, “Center”));
uib.AppendBlock(Button(“RemoveButton”, RemoveButton, 6, 1, 1, 1, 100, 30, “Center”));
uib.AppendBlock(CheckBoxList(“SelectedChannels”, 5, 3, 2, 1, 200, 300, false, SelectedChannels));
uib.AppendBlock(Button(“CreateButton”, CreateButton, 8, 1, 0, 3, 180, 30, “Right”));
The first number in each method (button, checkboxlist, etc) is the row, then rowspan, column, then column span. Those are then followed by the width & height.
So in the code above, the “AddButton” and “RemoveButton” are in the same column but different rows, and they both have a width of 100 and height of 30.
Hope this helps. Thanks
Joey Vanhalst [SLC] [DevOps Advocate] commented 5th January 2023
Hi Blake, if you are not yet familiar, you can also use the Interactive Automation Toolkit to more easily build your interactive automation scripts. See https://community.dataminer.services/documentation/getting-started-with-the-ias-toolkit/ how to get started.
Lander Vanhaverbeke [SLC] [DevOps Member]1.00K Posted 4th January 2023 3 Comments
Hi Blake. I don’t see any mistakes in the code you provided, so it looks like this is caused by a bug in web IAS. At the very least there is a difference in building the layout between Cube and web. Can you create a task for this and assign it to Automation & Orchestration for investigation? Attach the script, or a test script that reproduces the issue to the task.
Thanks for reporting!
Lander Vanhaverbeke [SLC] [DevOps Member] Posted new comment 24th February 2023
Matthias Declerck [SLC] [DevOps Advocate] commented 4th January 2023
Task: https://collaboration.dataminer.services/task/201450
Lander Vanhaverbeke [SLC] [DevOps Member] commented 23rd January 2023
FYI: We picked up this task.
Lander Vanhaverbeke [SLC] [DevOps Member] commented 24th February 2023
This has been fixed with RN35504 and will be available in 10.3.0 CU1 and 10.3.4.
