Low Code App: Creating a way to review SRM Bookings for Low Code App Users
Solved2.91K views3rd October 2023Bookings feed LowCode lowcodeapps SRM resources
Michael Wells [SLC] [DevOps Member]502 28th September 2023 0 Comments
I am trying to create a way for users of a Low Code App to see SRM Bookings created by the SRM/DOM/LCA solution I am developing, so they can validate that each SRM Booking is using the correct resources without requiring Cube.
I have created a list object and assigned the URL feed "Bookings", but this appears to have a very limited dataset:
First, is there a way in LCA to expand the fields available in this URL Feed to include items such as the date, start time, end time, etc?
Is there another type of Feed or Query that could be used to get this detailed Booking information and display it in a LCA?
Is it possible to build a feature within the current LCA available features that would allow a user to select a booking and it would feed another LCA object that would display a list of all the resources assigned to that Booking, and if possible, how would I do it?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 3rd October 2023
Matthijs Favorel [SLC] [DevOps Advocate]2.63K Posted 28th September 2023 0 Comments
Hi Michael,
I have created multiple Low-Code apps that display booking data.
As an example, this app lists all the "Shared sources", these are contributing bookings used in multiple other bookings. When a shared source is selected in the top table, the bottom table lists all bookings (orders) that are using the shared source.
An other example is this app that lists all main bookings (orders), when selecting one, it will list all sub-bookings (called services here):
Both of these apps use a custom GQI data source (as the default "Get Bookings" data source can't retrieve properties, which was required in my case)
Matthijs Favorel [SLC] [DevOps Advocate] Answered question 28th September 2023
