Logs on a remote dataminer cube not appearing. How can I fix this?
Solved3.10K views16th August 2023Cube Logging logs
Tomás Martins [SLC] [DevOps Member]246 29th December 2022 2 Comments
I am connected to a customer dataminer system via my dataminer cube. However, I can't see the logs on any element of that system. I also don't have permission to access the machine through RDC.
I have confirmed that my user has permissions to see the logging. Is there a way I can fix this?
Thank you.
EDIT: The Dataminer Log doesn't work as well:
There are no errors/exceptions on neither page, just blank.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th August 2023
Wim Bruynooghe [SLC] [DevOps Advocate] commented 2nd January 2023
Which DataMiner version are you using? Which default web browser engine is configured in Cube (see System Center, System settings, Plugins)? Is there anything related in the logging of Cube?
Marieke Goethals [SLC] [DevOps Catalyst] commented 7th July 2023
I see that this question has been inactive for some time. Have any of these answers helped you find a solution yet, or have you found a solution in the meantime? Could you select the best answer or add your solution in that case, so we can close this question? If no solution has been found yet, feel free to contact techsupport@skyline.be for assistance.
Jeremiah Allen [SLC] [DevOps Advocate]1.10K Posted 29th December 2022 0 Comments
Hey Tomas,
Are other users experiencing similar behavior? If so, the issue likely resides on the server side. So, troubleshooting will require direct access and trying some of the below steps.
  • You could first try recycling the IIS DefaultAppPool/restarting IIS
  • If the agent was recently installed/upgraded maybe IIS is misconfigured. In this case, rerunning the recent upgrade package might help
