Login issues while connecting web clients and Cube on Microsoft client OS version
Solved1.51K views18th July 2023Cube Logging Web client connect
Divagar Vijayarangan [DevOps Advocate]50 27th July 2021 0 Comments
Hi All
One of our client had version mismatch error alarm when they login into DM client / cube . It had cleared now post clearing XBAP files .
But got another problem , when user try to login it is showing incorrect login though it is valid credentials .
They are running below client OS on their machine. Is there any compatibility with client OS?
Have you or any of the clients faced this issue before ? Mobile version works fine in Chrome on the same machine.
Edition Windows 10 Pro
Version 21H1
Installed on ‎8/‎4/‎2020
OS build 19043.985
Experience Windows Feature Experience Pack 120.2212.2020.0
This was the previous post which i created last week just for reference for version conflict.
Version conflict error – Cube / Web client connect
OS & IE version on  machine.
Christine Kapembe [SLC] [DevOps Advocate]1.01K Posted 27th July 2021 1 Comment
Hello Divagar,
I am not familiar with a behavior where DataMiner fails to authenticate via Cube but works via the mobile application.
Please send an email to techsupport@skyline.be, so that we can create a task to have this issue investigated. Alternatively, please feel to create a task on Collaboration.
Divagar Vijayarangan [DevOps Advocate] commented 27th July 2021
Ok thanks Christine, will open task with support team.
