Localhost connection error after agent installation
Solved3.48K views28th March 2025Errors firewall locahost locathost connection
Ashok Mahala [DevOps Member]249 17th September 2024 2 Comments
After applying the license when I am trying to connect with Dataminer Cube using localhost after giving credentials one error is coming.
I have attached the error screenshot. Can anyone please help me to solve this issue. I have disabled firewall and restarted the system. I am still facing this issue.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th January 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Edib Šupić [SLC] [DevOps Enabler]2.56K Posted 17th September 2024 5 Comments
Hi Ashok,
others have experienced similar issues before, for them issues were mostly related to firewall settings. Can you check out this post and see if it helps?
If the previous post doesn't help you solve the issue can you have a look at some of these?
Hope this helps and let me know if you need anything else,
Cheers
P.S.
Please let me know how you resolved your issue(I'm curious), hopefully you will 😀
Ashok Mahala [DevOps Member] Posted new comment 18th September 2024
Ashok Mahala [DevOps Member] commented 18th September 2024
Hello Edib, I am not able to get anything much relevant from the questions you have shared. When i am trying to access the same URL from my browser i am able to access these pages using http but not with HTTPS, In Cube side also i have configured as Http or Https then why it is trying to access https if http is working then i should be able to connect with http right? Can you please look into or clear me the steps what i have to do ?
Edib Šupić [SLC] [DevOps Enabler] commented 18th September 2024
Hi Ashok,
Can you share your connectionsettings.txt and SLErrors.txt?
Yes I can, Please share me the mail where I have to share because here I can only attach media files.
You can just copy them here, I would suggest in a new comment instead under this one so you can format it a bit more nicely(it won’t be perfect either way, just nicer). You understand I can’t just post my mail here 😀
I have updated this content as Start a new answer please check and let me know where the problem is ?
