LCA with interactive script using DateTimePicker: How to set DateTimeFormat
Solved980 views27th April 2026LCA Interactive script DateTimePicker
Harald Schwarz [DevOps Advocate]597 9th April 2026 0 Comments
In our LCA we have an interactive script using DateTimePicker. Here we want to have specific DateTime format by setting DateTimePicker.CustomTimeFormat = "dd.MM.yyyy HH:mm". But this doesn't change anything. DateTime is always displayed in this format
Harald Schwarz [DevOps Advocate] Selected answer as best 27th April 2026
Robin Debel [SLC] [DevOps Advocate]2.36K Posted 14th April 2026 0 Comments
Hi Harald,
This setting is specific to Cube. In DB/LCA, the datetime format used in the timepicker component is fixed to dd / mm / year hh:mm".
If you would like to see this configurable or supported in the web environment, I recommend submitting a Feature suggestion.
Kind regards,
Robin
