LCA – Template editor : Where do I need to place images and how can I reference them using html
Solved641 views26th June 2025
Conan Van Hove [SLC] [DevOps Advocate]877 13th February 2025 0 Comments
I want to use an icon svg file in a grid component using html code in a text box in the template editor. But I don't know where precisely to put the image under the Skyline DataMiner folder or how to reference it correctly.
Can you please provide a clear example (so the exact location and the related html code) or refer to the documentation where this is described.
Thank you.
Wout Mahieu [SLC] [DevOps Catalyst]11.61K Posted 14th February 2025 1 Comment
Hi Conan
To use images in the LCA, you can put them anywhere they can be accessed remotely via HTTP. An example of this is the C:\Skyline DataMiner\Webpages\public folder.
Including the image in a template can be done by writing custom HTML in a text shape. In this example I have a template that is 256x128px where I have displayed my image using: <img src="/public/pizza.png" style="width: 236px; height: 108px; object-fit: contain">
Conan Van Hove [SLC] [DevOps Advocate] commented 14th February 2025
Perfect! Thank you.
