LCA – Passing value of a variable to script
Solved1.24K views28th March 2025LCA variable
Felix Wesemeier [DevOps Catalyst]2.54K 27th March 2025 4 Comments
Hi community,
I would like to use the value of a LCA variable to an IAS Component running in a different channel
Input is a variable of type table, used in a grid component.
When a grid item is selected, the selected value of one column is stored in another (text) variable.
This works fine e.g. when displaying the text variable in a text box.
However, when I try to pass this value as a script parameter input, it is always empty.
How can I achieve to pass the value?
Grid Action in Panel 1:
IAS component in Panel 2:
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Wout Mahieu [SLC] [DevOps Catalyst] commented 27th March 2025
Hi Felix, I just tested this myself and it seems to work. What DataMiner version are you using?
Felix Wesemeier [DevOps Catalyst] commented 27th March 2025
10.5.3.0-15484
Updated to 10.5.4 and it looks better now
Yeah, solved with 10.5.4.
Thanks Wout
Felix Wesemeier [DevOps Catalyst]2.54K Posted 27th March 2025 0 Comments
Just to close the question: Everything works fine after updating to 10.5.4
