LCA link in cube seems missing
Solved2.82K views26th March 2025DaaS LCA
Thijs Vanovenacker [SLC] [DevOps Advocate]2.71K 30th May 2024 1 Comment
After deploying a Low Code App onto a system, we expected to also see the link appear in Cube under “applications” or “Web Apps”  (after reconnecting this still seems to be missing).
We do confirm that the LCA is available and reachable on the system, we are simply missing the link directly from Cube.
Is there any configuration that we need to do?
Note that this system is running as a DaaS DataMiner.
Version: DataMiner (10.4.6.0-14348)
Shawn Michaud [SLC] [DevOps Advocate] Posted new comment 26th March 2025
Shawn Michaud [SLC] [DevOps Advocate] commented 26th March 2025
I still see this issue happening in the latest releases of dataminer and for DaaS's this is a problem as most users won't have RDP access to tweak the config file. Is this still on our radar to resolve or bring the config maybe into cube maybe?
Thibault Heylen [SLC] [DevOps Member]1.51K Posted 30th May 2024 1 Comment
Dear Thijs,
Thanks you for this, we also noticed this and worked in our last sprint on this. A fix should be available in the new DaaS image.
If everything goes well with validation, this should be released early next week.
Our task: https://collaboration.dataminer.services/task/236039
Thijs Vanovenacker [SLC] [DevOps Advocate] Selected answer as best 3rd June 2024
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 30th May 2024
Thanks Thibault. Maybe also interesting to note that I also came across this link (see below),
Where they mention that when defining sections to manage & group the applications, that these sections will also reflect in cube. We are looking forward to that fix, as opening the APP will be easier that way.
https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/Low_Code_Apps/Low-Code_Apps_configuration/LowCodeApps_organizing_landing_page.html
David Joseph [SLC] [DevOps Member]417 Posted 30th May 2024 0 Comments
Docs seems to mention that it should show by default any of the low code apps
“Web Apps: The Monitoring app, Dashboards app, and any available low-code apps.”
see https://docs.dataminer.services/user-guide/Getting_started/The_DataMiner_User_Interface/DataMiner_Cube/Cube_UI_components_X/DataMiner_Cube_sidebar.html#apps-pane
On the other hand you can explicitly add apps to a specific section by configuring them as follows and then they should show up in Cube as well.
David Joseph [SLC] [DevOps Member] Answered question 30th May 2024
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 3rd June 2024 0 Comments
I have the same issue today.
It looks like there are 2 flags on the LCA, IsPublished and IsPublic.
Both need to be set on True if you want this to be seen in Cube.
The top one is the the one missing in the link. The bottom is shown in Cube.
I assume it is an issue in the web software.
I do hope this helps us further.
Matthias Declerck [SLC] [DevOps Advocate] Answered question 3rd June 2024
