LCA input fields validation
Solved509 views15th September 2026DOM LCA
Alija Kusur [SLC] [DevOps Advocate]879 15th September 2026 0 Comments
Hi all,
Is there a way to validate input fields in LCA, for example, to validate URL input field contains no spaces?
Alija Kusur [SLC] [DevOps Advocate] Selected answer as best 15th September 2026
Wout Mahieu [SLC] [DevOps Catalyst]12.48K Posted 15th September 2026 1 Comment
Hi Alija,
There is no way to validate input using the input components in LCAs. Instead, you can do this using interactive scripts, which can be embedded in LCAs using the IAS component or script actions.
Alija Kusur [SLC] [DevOps Advocate] Posted new comment 15th September 2026
Alija Kusur [SLC] [DevOps Advocate] commented 15th September 2026
Great, thanks for the answer.
