LCA – How to use a QUERIES result in a web component
Solved1.11K views4th April 2025
Stefan Schedletzky [DevOps Advocate]2.48K 2nd April 2025 1 Comment
the user can enter a value, which is needed as an identifier.
With this one I made a query and it's showing only one entry. But I can't use this in the web component.
If I use a Parameter table and manual select it I can use it, of course I want to link it to the user input.
What is the best way to achieve it?
Basically the information is in a static element in Dataminer, just need to filter on the user input and you get a link. This one I want to use.
Stefan Schedletzky [DevOps Advocate] Selected answer as best 4th April 2025
Steve Purcell [SLC] [DevOps Advocate] commented 2nd April 2025
Hi Stefan, take a look at https://community.dataminer.services/question/is-it-possible-to-pass-view-id-to-web-component-to-open-specific-monitor-page/ this may be what you are looking for.
Stefan Schedletzky [DevOps Advocate]2.48K Posted 3rd April 2025 2 Comments
Hi Wout,
when I use it like you mentioned I can't select it in the component:
I have enabled select first row, but data will be shown when the user is entering something in a field. So why I can't use it in the web component?
Stefan Schedletzky [DevOps Advocate] Posted new comment 4th April 2025
Wout Mahieu [SLC] [DevOps Catalyst] commented 4th April 2025
Hi Stefan,
To have the data from the table available for linking to another component, you will have to make sure there is at least 1 row & that row is selected. This doesn't mean that the link will stop working if the table would become empty at any time, it is just to be able to configure the link. This is a limitation of our current data linking framework that we are actively working on fixing.
Stefan Schedletzky [DevOps Advocate] commented 4th April 2025
Hi Wout, thanks it's working now!
