LCA – How to insert conditional cases?
Solved343 views16th January 2026LCA
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 16th January 2026 0 Comments
In my LCA while customizing a table column template I want to add a conditional case on a certain position. How can I achieve this without removing all of them and rebuilding it from scratch?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 16th January 2026
Wout Mahieu [SLC] [DevOps Catalyst]11.61K Posted 16th January 2026 2 Comments
Hi Jens,
Unfortunately there is currently no way to re-order these using the LCA UI. The only way to achieve this is by re-creating them in the order you need.
Jens Vandewalle [SLC] [DevOps Advocate] commented 16th January 2026
Hi Wout, also not by doing some changes in the json files? I have more than 7 cases already. I guess recreating them will take more time than making some changes in the json?
Wout Mahieu [SLC] [DevOps Catalyst] commented 16th January 2026
This is indeed possible, but isn't straightforward and can be error prone. Locating these conditions in the config-file of your page and re-ordering them should work for your case.
