[LCA] – GQI performance issue
Solved2.49K views23rd January 2025LCA
Kévin Dugué [DevOps Enabler]863 17th June 2024 2 Comments
In my page, there is a table component associated to a GQI query "Get object manager instances" for displayling data.
There is in database thousand instances for the DOM definition i chose and the number is set to increase considerably.
When i refresh the page, the loading time is reasonable (3-4 seconds).
I added a Column Custom Operator to the query. And now the loading time is excessive long (30 seconds).
If i 've understood the doc correctly, if i do not have filter, it is not possible to optimize custom operators, thousand instances will be scanned? Optimizing your custom operator | DataMiner Docs
How can i improve performance?
Do i need to create a custom GQI ad hoc source with paging?
public GQIPage GetNextPage(GetNextPageInputArgs args)
Do you have an example of usage?
Thanks
Kévin
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the most relevant answer (this can also be your own answer)?
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 17th June 2024 0 Comments
Hi Kévin,
A custom operator is indeed a great way to extend, transform, and manipulate data. A custom operator will, for example, do something with each row (in your case, probably adding a value to the added column).
Unless some expensive operations are needed to generate that value, the impact of a custom operator on performance should not be significant.
However, there is one important sidenote: With GQI and the DOM Instances data source in this case, we try to fetch the data as efficiently as possible. This means that if a user adds a filter operator in the query or uses the filter option in the table header, we try to forward that filter as close to the database as possible. But if there is a custom operator in your query between the data source and the filter operator, we can't know if we are allowed to forward the filtering to the database. Because of that, we need to go into post-filtering mode, which means that GQI will do the filtering in memory, which will be less efficient.
To address this, we introduced the feature described in the following tutorial: https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/GQI/Extensions/Custom_Operator/Tutorials/Custom_Operator_Tutorial.html
Through this mechanism, you can indicate that filter operators might be forwarded if applicable.
Does the above mentioned reason explain why the performance has decreased significantly? If so, I would suggest to apply the optimization as shown in the tutorial.
Feel free to let me know if anything is unclear, I can further assist you.
Best regards, Ward
